Turn night vision mode on and off at a preset time
Is there a way to set the night vision to turn on and off at a time I select instead of using Auto mode? There are street lights that my camera faces that never allow night vision to turn on leaving it in color night vision. It is okay, but it actually blinds my camera, not allow you to see much. But if I manually turn night vision mode on, then the image is clear and I can actually see what is going on. I hate having to remember to turn it on each night and would like to be able just set my on/off time once and be done. Thanks!
Welcome to the Wyze User Community Forum @gregd383! :man_raising_hand:
Unfortunately, there is currently no way to access the Night Vision On\Off without manually opening the app, entering the settings, and toggling the settings. The Auto feature uses a pre-set light level determined by the light sensor in the cam and the firmware.
There are Wishlist requests asking Wyze to add the IR NV Toggles to Rules, but they have yet to be developed. If you Search the topic below for “Night Vision”, you will see all the requests asking for it so that IR NV can be scheduled.
