The firmware update instructions are wrong, at least for the Mac.
says “For Windows 10: Right-click on the folder and select extract all. For Mac: Just drag and drop the folder, put it on the root directory of your microSD card. For both Mac and Windows, rename the file to demo.bin.”.
The downloaded file is a ZIP file, not a folder.
Windows users must “extract” the file, while " Mac: Just drag and drop the folder"
That indicates to me DO NOT EXTRACT. But then the instructions are wrong by calling it a “folder” in the first place.
For Mac users, these instructions are no help at all. In fact, Mac users must
- ignore the “folder” description, and 2) then unzip the file for it to be used.
The renaming instructions are correct.
