How to flash v2 what file do I use
I’m trying to flash my V2 cameras I don’t know which file I’m supposed to use like to put on the SD card to flash it
You will find all Wyze firmware on this link. Which v2 firmware version you pick might depend on your situation. If for example the most recent is causing problems, I would try one version back.
Here is more info on the manual flash procedure if needed.
Welcome to the Wyze User Community Forum @mikepratte25! :man_raising_hand:
Here are the instructions on how to Factory Reset your cam and Flash the Firmware. The link @StevenA posted is where you will get the firmware for your V2 cam. There, if you select the V2 cam, you will see blue links of the firmware version number that will download a .zip file. The .bin file you need is inside that zip and will need to be extracted to the 32GB SD card you use. For the V2 Cam, the file will need to be renamed to demo.bin if it isn’t already. Make sure your computer shows you the file extension (.bin) before you rename it. If your computer isn’t showing you that file extension and you add it, the file will actually be demo.bin.bin and it will fail.
https://support.wyze.com/hc/en-us/articles/360031484511-How-to-factory-reset-your-Wyze-Cam-v1-v2-v3-or-Pan-v1-v2
https://support.wyze.com/hc/en-us/articles/360031490871-How-to-flash-your-Wyze-Cam-firmware-manually
Welcome to the user-to-user forum, @mikepratte25!
Do you have a problem you want to fix with an SD card manual flash? Otherwise just let normal camera over-the-air firmware updates do the trick. :slight_smile:
Just wanted to help anyone struggling with this and their v2 … the “How to flash your Wyze Cam firmware manually” specifically says:
1. Ensure the unzipped folder is named “demo.bin”.
    • If not, rename it.*
      2. Drag the folder to the root directory of the microSD card and then remove the card from the computer.
However - this is incorrect. The filename needs to be demo.bin and this demo.bin file MUST NOT BE IN A FOLDER on the SD card. The demo.bin file itself needs to be in the root directory of the SD card. No folder named demo.bin or this will not work.
I almost gave up until I watched this; https://youtu.be/vzu5aNePOz8?si=VeJVdjdDRonNa6r-&t=128 which specified the FILE is in the root directory not in a folder at the root directory.
I hope this helps someone.
Thanks, I’m going to report this. It looks like more than one of the cameras instructions say folder instead of file.
I didn’t check the others, but the v2 instructions still say to use a folder on the SD Card instead of the file.
Thanks.
I think if nobody gets around to fixing this soon from my backend communication, I’ll just post it publicly in the next AMA.
#AMA2ASK (this is to remind me to bring it up)
