Firmware for wize cam & scan
My firmware update bombed during the process of installing it. My cam is useless now is there anything I can do?
Welcome to the Wyze community!
You should try a factory reset.
https://support.wyzecam.com/hc/en-us/search/click?data=BAh7CjoHaWRsKwhfeozTUwA6CXR5cGVJIgxhcnRpY2xlBjoGRVQ6CHVybEkib2h0dHBzOi8vc3VwcG9ydC53eXplY2FtLmNvbS9oYy9lbi11cy9hcnRpY2xlcy8zNjAwMzE0ODQ1MTEtSG93LXRvLWZhY3RvcnktcmVzZXQteW91ci1XeXplLUNhbS12MS12Mi1vci1QYW4GOwdUOg5zZWFyY2hfaWRJIik1OWQ1NTg5MC1mNmM5LTQxNjQtYTAzZi01MGJkY2IwMjkxN2UGOwdGOglyYW5raQo%3D--1060790e3381c8f45f8a6553b737626d2c3333cf
let me know how it works!
What @Brlepage said, then maybe
Manually flashing the firmware almost always restores the cam, especially if the firmware was corrupted during upgrade.
You can reset it… Unplug from the camera, hold down the setup button on the bottom while you plug the cable back into the camera.
I believe that is the process, google it or search in Wyze for it
