I am new to TinyCam and I just downloaded the PRO version last night.
Now I need some more help:
I found these instructions which have been helpful:
https://docs.google.com/document/d/1eQ5WSHWy7Vd6c70uw6c19z9zh7tQN_AM9g9I0wWk294/mobilebasic
But I am stuck at #5:
I have copied the instructions below. I have a Comcast Xfinity router and wifi in the router. I dont know how to get the information explained below so I can view my TinyCam Pro on a PC outside my local network.
Help is appreciated ![]()
5. At main menu switch the “Web Server” switch to the right. Your Android device is now serving your camera feeds at the address indicated with the arrows.
- From your web browser navigate to the address shown on your device.
- For access outside of your local network you would need to setup port forwarding. Follow your particular routers instructions
*** On you router- forward the port that is serving on TinyCam (ex. 8080) to the IP address that is hosting the webpage (ex. 192.168.0.20).**
*** Access your external IP address from outside your local network. (ex http://64.233.160.120:8080)**
