TinyCam Pro on iOS
TinyCam Pro does not see my Wi-Fi but did see all my cameras. Is anyone else having this issue?
I am confused. TCP uses the connection of the device on which it is installed. If that is your phone, it is your phone’s connection to WiFi or Mobile Data, if your TV or Streaming Device, it is the Network Settings within that device that provides TCP Internet access. TCP doesn’t need to see any WiFi. It uses whatever internet connection it is given by the device it is on.
If it loaded your cams, where is it getting its internet connection to authenticate on your Wyze account and P2P stream your cams?
It loaded the cams but they are all showing offline. My phone is on the WiFi.
Regards,
Moderator Note: Personal information has been manually removed from this post. Such information often gets included inadvertently in an email signature block when replying by email. The forum software attempts to automatically remove email signatures but it is not always successful. When replying to the forum by email, it is best to remove the signature block yourself before sending.
Bryan, when you reply from an email, please be sure to remove all personal info from the email (auto signature) so that it doesn’t get posted to the forum.
Are the cams online in the Wyze App?
Is this the first time you are adding cams to TCP or do you already have other cams that stream successfully in TCP?
I thought tiny cam pro was exclusively only on android play store? :face_with_monocle:
I only use Android, so I don’t know if\how it runs on iOS.
To the best of my knowledge it has never run on iOS only Android.
:thinking: interesting. That just adds to the mystery then considering the title and tags above. I’m starting to hear the Twilight Zone music.
