Is there a way to time sync all cameras at once, instead of having to drill down in the settings of each one separately?
This is currently not possible. The #wishlist is used for feature suggestions though.
Is there any reason you need to do this? Usually you should only need to sync the time very rarely. I think power cycling the cam probably syncs the time, but could be wrong
Thanks. They seem to get out of sync after a while. Nuisance to have to update each one individually.
