Hi all,
Dumb question time - after the time change a few weeks ago, my cams did not go back 1 hour.
How can I set the time?
Thanks.
Hi all,
Thanks.
Is your mobile device on the correct time?
If so try clicking on the sync time utility found under settings, advanced settings of the camera.
They will not do it its in your app I think its under the advanced
That did it, thank you very much. (I mean, clicking on sync)
I’m surprised it’s not automatic though.
