Things That Go "Jump" In The Night
Technically captured by Wyze… I have a camera looking out my front window and it’s practically impossible to turn on motion detection without getting a ton of false positives (reflections on window, sunlight, dog in window, etc.). So I had the brilliant idea to put one of the motion sensors on my front patio. I know they’re not made for outdoors/weatherproof/yadayada, but considering how well the cameras hold up outside I was willing to potentially sacrifice a sensor for science. I installed it around noon and it worked flawlessly all day. Fast forward to 9:30PM, I’m sitting on my living room couch and I get a notification of movement on the front patio. So I jump up and run to the front door and look out the peephole. Nothing. Thinking maybe the sensor had fallen down (for testing purposes I used double-sided tape, and it’s very hot/humid where I live) I walk outside and find this:
Clearly my brilliant idea was thwarted by some stupid green frogs. Hopefully you all have better luck!
( spider man/ spider pig theme) spider frog, spider frog…does whatever a spider frog does………
Oh man, I see your problem … your motion detector lens is frogging up!
Too funny, you all!! :rofl::rofl::rofl:
apparently Wyze cams are a hopping good time for everyone!
Better try that before I froget. :slight_smile:
at least you didn’t JUMP to conclusions about what it was before actually figuring it out.
Blockquote
I get lots of false positives when its that froggy out.
That frog really makes sense! :frog: :grin:
