Hi I just received two Wyze Thermostats, and when I tried to set it up, the app keeps saying my system is not compatible. Very simple two wire (red and white) heat only furnace, to which I have several Nest Thermostats working fine. Regardless of whether I choose R or Rh or Rc with W1/W2, I get the message that my system is not compatible.
Why do you have 2 wires going to the red terminal? If you felt comfortable opening up your furnace, it would be helpful to see your furnace board. It might be possible to connect the wyze to your setup, it depends on how the wires are connected in your furnace
Also watching this. I have a 2-wire system that was connected to an old Honeywell circular dial mercury thermostat. I can’t believe Wyze didn’t include any instructions with how to convert, if it’s possible. Big Wyze fan, but they dropped the ball on this one.
Not a problem. Pulling wires is no big deal for me, so hopefully a relatively easy fix. Planning on just using the old ones as my wire-puller for the new one. Thanks!
I also have this configuration on a Lux programmable thermostat. Can’t we just mirror the same thing on the Wyze? White wire to W, then Red wire to RH on Wyze…, Then the same jumper wire that is shown here connecting the RC and RH? Seems like this should work on this one too. I don’t know. Came here hoping to see that others have already done or not.
The wyze does not use a battery, it only gets power from the wires connected to it, so if there are only 2 wires, when the wyze connects them together for a call for heat, it would shut off due to not having power anymore. Therefore, the wyze requires a minimum of 3 wires, 2 to power itself, and 1 to do something useful
Thanks Speadie for the information. That helps me (and likely hundreds of others) understand the difference between this and my existing programmable thermostat. And more importantly why this new product won’t work on my simple two-wire heating system.
