My system is working at this point after I deleted and reset the thermostat and changed the wiring (see the Dropbox link below). However, as others have said I’m concerned that it is not working as efficiently as it was with the old thermostat. Also, I have lost the basic functionality of manual control of the auxilary/emergency heat and the indicator that manual/emergency heat is activated.
Below is the exchange in progress with support including my system details, a link to wiring details and the screenshots they asked for. Note that Wyze support has indicated there is a “Differential Temperature setting” and the ability to activate the “emergency auxiliary”, neither of which I can find.
Re: [Wyze Ticket XXXXXX] Re: Thermostat not working correctly
Tue 12/29/2020 12:41 AM
The Emergency Heat and the Auxiliary Heat are the same on my unit (electric heat strips within the unit). The old thermostat has a setting for “Em Heat” that can be used to manually activate the heat strips in case the compressor unit fails.
My system is composed of the following equipment installed in 2015 (the wiring diagram in the Dropbox folder link below is from the Trane system documentation):
Trane 4TWR4 Heat Pump
Trane TEM4 Air Handler
Honeywell FocusPro 5000 Series Thermostat (replaced with Wyze)
Documentation for these is easily found online.
Phone: Google Pixel 3 XL running Android 11
Here is a link to a Dropbox folder that has screenshots and pictures:
Thank You,
Sent: Monday, December 28, 2020 8:58 PM
To: <'s email>
Subject: [Wyze Ticket XXXXXX] Re: Thermostat not working correctly
##- Please type your reply above this line -##
Your ticket (XXXXXX) has been updated. To add additional comments, please reply to this email.
Sharlyne (Wyze)
Dec 28, 2020, 5:58 PM PST
Hey there, !
Kindly send us a screenshot of your Wyze App on the thermometer. Also, can you please clarify which heat were you referring to? Is it the Emergency Heat or the Auxiliary Heat?
Thank you and we will wait for your reply.
Sharlyne | Wyze Wizard
Visit our Help Center: click here
Website | Facebook | Twitter | Instagram | YouTube
Dec 28, 2020, 12:08 PM PST
Thanks for your reply. Can you explain this please?
1.) Where/How do I find the “Differential Temperature” settings? How do I access this setting?
2.) Where/How do I find the setting in the Wyze app and on the thermostat to manually activate the emergency auxiliary?
3.) Again, is there any indicator in the app or on the thermostat to indicate when the auxiliary or emergency heating has been activated?
Sharlyne (Wyze)
Dec 28, 2020, 11:32 AM PST
Hi , thank you for your reply.
Wyze Thermostat has a Differential Temperature setting available which allows you to customize the threshold for when the heating or AC will turn on. This allows you to set the threshold for when your heating or AC will turn on, with a range between 0.5-2.0 degrees in half-degree increments. This allows you to fine-tune your system to work how you want.
About your question, once the4 compressor fails, the emergency auxiliary can be activated from the settings of the Wyze app and on the thermostat.
We hope that helps! If you have any additional questions, please reply back to this email so that we can assist your further.
Thank you for being part of Wyze. Stay safe and healthy!
Dec 28, 2020, 7:19 AM PST
Thanks for the response. I have it working now but I’m not entirely sure it’s working correctly. I’d like to know how the thermostat operates when using a heat pump. Could you please answer the questions below?
What conditions cause the 2nd Stage or Auxiliary heat source to be activated?
Is there any indicator to let you know that Auxiliary/Emergency heat has been activated? Is there any way to know this?
What happens if the heat pump compressor fails, is there any way to activate Auxiliary/Emergency Heat manually as there is on most heat pump thermostats? I don’t see any way to do this.
Thanks,
