Thermostat temperature
I recently installed my Wyze thermostat and it doesn’t seem to switch off the heat at the correct temperature.
You can see from this screenshot that the thermostat is set to 69 degrees but it is actually 72 degrees in here.
It’s a huge waste of energy and it’s way too hot.
The heat did stop at 72 degrees.
I have differential temp set to 0.5 degrees and temperature correction set to -3 degrees (as it was incorrect when I installed it).
Any ideas?
The wyze logic tends to have a fair bit of swing. Just the way it is programmed, I’m afraid.
