Handful of problems with my Wyze Thermostat. Anybody else experiencing these?
-The thermostat reboots on user input to the thermostat itself. It’s not consistent where on the menu it reboots. Wheel turns and push buttons both cause reboots.
-The number 7 was displaying incorrectly for a while, but seems to have corrected itself.
-First attempt at firmware update via iOS hung and failed. Tried again via same tablet and had success.
-During the same time that he number 7 displayed incorrectly, the thermostat would not call heat or cool or fan. The app indicated that it was calling for these, but it wasn’t happening in real life.
-Today, the 7 displays correctly and heat and cool both run as they should, but the reboot problem persists. I changed nothing at all… the issues that corrected corrected on their own.
Simple 5 wire single stage heat and cool setup with a c wire. 28V from red to blue.
Pretty unhappy so far and dreading what’s in store when the robot vac arrives.
