I know you can view in the app if hvac is currently on (heat or AC) as it is also color specific (orange for heat, blue for AC). I don’t see that when you are in front of the thermostat as it just shows current temp. Question is, if looking at thermostat how do I know if the heat or AC is on?
The thermostat turns orange like the App when the heat is on, although in my case there often seems to be a discrepancy between the two and sometimes the App will be orange and say it’s heating, but the heater is not (yet) on and the thermostat is still grey. In that case the temperature in the room is one degree below the set temperature. I’ve submitted a support ticket with Wyze about that but haven’t heard back yet.
