Thermostat Lock with code
Is there a way to lock the settings on the thermostat with a passcode?
Welcome to the Wyze User Community Forum @borntodubb! :raising_hand_man:
Yes and No.
No, you cannot apply any passcode but you can “Lock” the thermostat in the App so that it cannot be adjusted at the wall unit. However this can be circumvented from the wall unit if you go deep enough into the menus.
Thank you SlabSlayer, that is what it looked like. I need 10+ thermostats that can be locked with a PIN code, but I was hopeful that the Wyze locks would work.
