Is there a way to lock the thermostat to a particular temperature so that no one can change it. Either at one temperature or as a set schedule that no one can change?
Welcome to the Wyze community @radicaltype! You can lock it from the app by going to the thermostat, then se, then enabling the lock. You can still use app controls and schedules as normal.
