Temp lockout
So I have just received my wyze thermo stat and haven’t hooked it up yet, my question is, does this stat have the ability to be locked so you can’t adjust temp with control dial?
Honeywell has this feature and it’s nice if stat is being changed by people who shouldn’t be.
Yes it has this ability, in the app you can select control only with app.
What I would like though, is the ability to share access to the thermostat for information and for auto away, and yet lock out control directly by that app on that phone…
Thank you for your answer, appreciate it.
