Wyze calls their âdeadbandâ a âMinimum Comfort Zoneâ. It is mentioned in the Thermostat User Guide as a default 5° range that can be adjusted from 3° to 10°.
Iâm referring to the âtemperature differentialâ setting. 1 degree short cycles, and 2 degrees is noticeable. There is a 0.5 setting, a 1.5 would be reasonable in my opinion.
If your unit is short cycling on a 1° differential, it is either oversized for your space or the room with the thermostat is getting all the airflow in a much greater proportion to the rest of the house.
Again, this is something that you can submit for improvement on the #wishlist.
