Just changed out the thermostat at maybe a bad time when it’s 5F out side. The heat does not come on but the cold does eg they are switched. I have submitted a support request but family is not too happy with me right now.
Not sure if I need to do a quick wire switch I have a 2 stage heating and cooling unit. It’s a Trane XR95
How is it hooked up to the wyze?
Also, the wyze blows cold air for a bit before the heat kicks on, it starts the fan up right away instead of waiting for the heat exchanger to get hot like most thermostats do. supposedly there is a fix coming for this.
That’s weird. What type of furnace did you tell it you had? Your wyze might be defective if it’s not calling for heat. Does the other thermostat still work?
You only have 1 stage. or at least only 1 wire for hot and 1 wire for cold. Your furnace is probably set to take care of the staging automatically.
You should try removing it from the app and resetting it at the wall and running through the setup procedure again, making sure to tell it you have the following wires: C, R, W, Y, G and a gas furnace.
Thanks for the help, Just did a reset and saw that the only option for a propane furnace is what I must have picked last time. After the reinstall the furnace does not want to lock on at all.
A slower steady flash indicates that it is not getting the call to heat. does it do that in test mode too?
I’d try hooking up your old control- if it works, call wyze and tell them you have a defective thermostat and they will send you a new one. If the old thermostat doesn’t work, then you have a broken wire somewhere.
Funny I just came up here and went in to the physical device and went in to it’s settings from the wall unit and it fired up the test mode but still clod air…
LoL a little strange I will test in a few minutes and see if the app works. But I think my unit has a short cycle protection so want to wait a few minutes.
One other strange thing I was thinking you could walk up to the control and just turn the knob right to turn on the heat? I turned it left and right and no change to the main number on the screen.
