Submitted ticket 147707 with logs. Pls help!
Donāt see a port to allow manual load of prior firmware. Hopefully there is a button sequence to get it to kick past finish and allow remote management to revert. Occasionally, it shows connected to cloud when I cancel out so itās getting connect before it spins. Just workin the options!
Sorry brother, I am out of suggestions, other than the WYZE ticketing system is not the fastest. I would suggest calling their support today.
Live support is available:
+1-206-339-9646
Monday - Friday 5 am - 6 pm PT
Saturday 8 am - 4 pm PT
I updated the firmware on the app but did not see it working. I deleted the app and re installed it and that did the trick, I also see the differential now.
Did you reset tstat and redo setup? I was testing for Stage 2 fix in setup. If not, donāt! ![]()
I called in and the āservice teamā is looking into my ticket ⦠in the meantime, picked up an eccobee 3 lite, as my final rollback (or would it be a rollforward) option ![]()
Heh, might have been better to open a new ticket while you had them on the phone vs. referencing one you opened online ![]()
Thatās a salty roll regardless of direction. Sucks you are having issues.
No resolution, so I requested a replacement. In process. Blah. Will install new ecobee, hopefully wonāt like it too much ā¦
Saw there was an update available
tap tap tap
Update failed
google google google
finds week old thread about 1.1.5b updates failing with no resolution yet
le sigh
