It would be great if auto mode worked like it does in cars, where you set the optimal temperature and it heats or cools to that instead of having to set a ‘heat to’ and ‘cool to’ range.
Maybe this exists already and I just haven’t found it yet
I upvoted another post that mentioned this. I’ll be returning two thermostats if this isn’t an option. It simply means my house will never be the temperature I want it unless I manually adjust temperatures based the weather outside. Absolutely insane I can’t set my home temp to 71 degrees and 68 at night…regardless of weather it had to heat or cool to that temperature.
