Thermostat App Display
I have two thermostats and recently one of them went from displaying the Heat and Cool to numbers to just displaying the cool to number. How do I get this back to normal? Examples of the original way it was displayed and how it’s displayed now are attached.
I think that’s the difference between “Auto” (Heat & Cool) and Cool Only (under Controls).
I just looked under the settings, and I don’t see this option. I see the auto switch which states that it uses your phone location to turn the AC on/off, but that’s it.
I don’t think it is available under settings, try here:
You rock!! I don’t know how I missed that, but my wife or I must have hit that switch when turning on the hold option. I searched and searched, but didn’t even think to check there. Thank you for your help!
