Tablet To Use
Sideload the Wyze app.
That’s strange…I just used the Google App store to load the WYZE app on my Nexus 7 earlier this week.
Not sure if the beta app is different, but just today I had no issue installing the Wyze app from the play store on a new Lenovo tablet running Android 10. I’m on beta though.
Which Lenovo model tablet was it? I am interested in getting a Lenovo tablet once I get all the cameras setup.
Removed
Why do you think Magisk would help?
Your tablet is already rooted. Wyze doesn’t block rooted devices.
They go through phases of not installing on certain tablets.
The files on APKPure are safe. There are no cracked versions of Pro apps.
It’s the Lenovo M10 Plus Full Hd. Mine is the 64 GB / 4 GB RAM version. There is also a 32 GB / 2 GBp version. https://www.amazon.com/Lenovo-Android-Octa-Core-Processor-ZA5T0263US/dp/B083JVJQH4/ref=mp_s_a_1_3?dchild=1&keywords=lenovo+m10+plus&qid=1610296506&sprefix=lenovo+m10&sr=8-3
Removed
That’s on my list…thanks
If you can get the Lenovo fof $129 don’t even look at the Walmart brand.
Actually Lenovo has one for $129…so I have a minimum of 2 locations to purchase
I know, that’s why I said to stay away from the Walmart ONN.
Update…I purchased the Lenovo M10 Tablet with Google assist and the Wyze app is working good. Thank Goodness. What I cannot find is a good definition of the ā€œSet Detection Distanceā€ for my Outdoor cameras. How do I tell where the close detection is versus the Far on my screen? If you set the distance as FAR, does that mean it will only detect at the top of the Green Area???
Thanks
Phil
Do you mean the Near and Far setting? If so, that’s not for detection, that’s for the IR led lights. There are two different ones on the camera, 940nm LEDs which are mostly invisible to the human eye and work best up close, and 850nm LED’s that glow red and work better for further away. For example. if you had the outside near a door, the near LED’s would be better for faces and such that are within like 4 to 8 feet from the camera. The Far LED’s would be better on the same camera for seeing further out into the yard.
I loaded TinyCam app on my fire tablet, but don’t know how to get my wyze cams onto the tiny cam app.
Can you help?
Thanks
The instructions are here.
Well it’s 2022 and I’m needing another display for my wyze cams,
What’s the current least expensive display tablet, the bigger the better?
I basically had to chuck about $500 worth of devices when they cut back on support last year so I don’t want to invest in a $500 tablet.
@gemniii (greenbeard) and @angus.black smushed together. What the heck happened to you guys? Where ya been? :slight_smile:
Speaking of which, where walks the stalking lion, @secondary_2g ? :grin:
I have been very happy with Lenovo tablets. I have an M8 FHD. They also have the M10.
They always have good sales direct from the Lenovo site.
I was thinking to get M8 FHD but read some users comments that M8 FHD speed is not snappy.
