Sync all cams time and restart all cams
I would like to know if there is a way to sync all cams time with a macro or single click. Also would be great if I wanted to restart all cams or just ones in a group.
Thanks,
Jack
You can’t sync all of the cameras times with one “click” but you can sync them with your phone/tablet.
https://support.wyzecam.com/hc/en-us/search/click?data=BAh7CjoHaWRsKwhfrq3TUwA6CXR5cGVJIgxhcnRpY2xlBjoGRVQ6CHVybEkiWGh0dHBzOi8vc3VwcG9ydC53eXplY2FtLmNvbS9oYy9lbi11cy9hcnRpY2xlcy8zNjAwMzM2NjA1MTEtSW5jb3JyZWN0LVRpbWUtZGlzcGxheWVkBjsHVDoOc2VhcmNoX2lkSSIpNTUxOWIxZmItZTNlZS00NTUwLWEyMTctNjg4MzcwY2FlNDc2BjsHRjoJcmFua2kG--9f833b67dd0707ff926baded7d1a3ab0778c89fd
You can’t physically power cycle/restart the cameras remotely without connecting them to a smart plug. You can turn them off then on from the Wyze app and this will sometimes give the same affect.
You can add the cameras to a group and then turn that group off then on again. You could also creat a shortcut to turn on and off specific cameras.
https://support.wyzecam.com/hc/en-us/articles/360030146191-Group-and-Sort-Products
https://support.wyzecam.com/hc/en-us/search/click?data=BAh7CjoHaWRsKwhgdnLTUwA6CXR5cGVJIgxhcnRpY2xlBjoGRVQ6CHVybEkiWWh0dHBzOi8vc3VwcG9ydC53eXplY2FtLmNvbS9oYy9lbi11cy9hcnRpY2xlcy8zNjAwMjk3Nzk1NTItVXNpbmctUnVsZXMtd2l0aC1XeXplLUNhbQY7B1Q6DnNlYXJjaF9pZEkiKTk3Yzc4NDI4LWZkZDctNDY2OC05Nzk5LWQ1YTU5M2NiOTQ1MgY7B0Y6CXJhbmtpCA%3D%3D--157f26321c9fbfdd66a899c34dee12e55c0000d5
I didnt realize there was option for group to restart. That is a GREAT option, as is essentually syncs time for cams in the group.
Thanks for your help!
Jack
