Switching the home WiFi to a new Router with new SSID and password.
What is the simplest way to switch a V2 camera that is on the Horrifuc CamPlus plan?
I do not see a simple way to do this so am thinking I have to remove the plan from the camera, reset the camera, then add the camera back and join the new WiFi, and then add the plan back. Please tell me that there is a better way. Thank you.
The way you described unfortunately is the only current way when you are switching the SSID and/or password
Of course you could consider replicating the old SSID… ![]()
