Switches and plugs offline
I have 5 switches in a distant location that have all gone offline. I can’t do a hard reset because of the distance and if I went there and did a hard reset what would prevent it from happening again. There’s no “local schedule” on wyze switches (like wyze plugs) so I can’t just wait for them to reset themselves. After all this time and wyze purchases maybe it time to look elsewhere? Anyone have any suggestions or explanations. I’ve sent in support requests. No answers yet and I don’t expect any except for the hard reset answer which I’ve said isn’t easy.
Oh and by the way the only way to install these switches in a 4 X 4 utility switch plate is by carefully cutting the ends off the switch with a hacksaw.
Check your PM queue for the response to your wishlist request asking for the same. Local schedules for Switch currently exist. Remote reset of a switch does not exist (unless you are wiring switches in series), but a wishlist topic for that feature is located here: Better keep alive coding for Wyze Switch
YoLink…they work extremely well and are reliable.
