I’ve been have alot of connectivity issues with my Wyze Switches (6 total) and it’s been annoying to need to reboot my whole network to get my Wyze switches to reconnect to the network again. On a daily basis 2-3 of my Wyze switches (all controlling Wyze Bulbs) will drop drop the network. Since the Wyze Bulbs can still be controlled via the Wyze App, Google Home, or Google Assistant, I can only assume that the Wyze Switches are the problem. My network consists of an Xfiinity gateway and 4 TP-Link Deco mesh extensions. All my switches are connected to my Deco mesh network, which is purposely kept separate from my Xfiinity WiFi, and on a timer to reboot every morning at 4 AM. I set the daily reboot to try and alleviate the connectivity issues. I have quite a few TP-Link Kasa switches (Dimmers, 3-way, and standard) and some cheap Gosund switches around the house as well and have virtually no issues with them. Rarely when one of the TP-Link switches does have a connectivity issue, it’s a simple push of the reboot button under the paddle and it reboots itself in a few seconds. I’ve been told that you can reset a Wyze switch by press and holding for 20 seconds, but honestly I have nearly all my connectivity problems from my 6 Wyze switches. My cheap Gosund switches don’t loose connectivity, or if they do, reconnect themselves, Wyze switchs shouldn’t either.
I would think that a firmware patch could easily be made to periodically (5-10 min?) could poll the WiFi for connectivity and attempt to reconnect or reboot itself.
Just a thought. With the exception of the Wyze night lights, (I threw those useless POSs in the trash), I love all my Wyze products, but this connectivity problems with the Wyze Switch is frustrating the hell out of me.
Kenneth R Zink II
