Support Landscape mode of the app
hi I wanted to use the monitoring tab on a tablet on landscape mode but the app don’t support that feature it’s there a way to use the app on landscape mode
I’m not aware of a way to do this currently, but it’s supposedly part of Wyze’s plan for this work-in-progress feature of the app:
:pencil2: Edit: I had another thought: If your goal is merely to be able to see four different camera feeds in landscape at once, then you could try sticking them in the same Device Group and then viewing that Group screen in landscape orientation (i.e., viewing a Group from the Home tab and not using the Monitoring tab at all).
Does not work. Home shows four images but one at a time and you have to scroll up to see the others
I wonder if that’s an iOS thing. I’m not an iOS user, and @Manasuazo’s profile also indicates Android use, which is why I made that suggestion.
I’ve read elsewhere on the Forum about ways to achieve a landscape view in iOS, but I can’t speak to that personally and currently have no access to iOS devices.
I am shocked that we have no ability to view the cameras and playback in landscape mode. Wyze just came out with a new update and it is still not there. Very very VERY disappointing and a reason the Wyze app falls short of its competitors. It can not be that hard. There must be some reason they do not allow viewing in landscape mode.
I do this frequently, both in the new v3.0 app and in the earlier app version, as I previously described. :man_shrugging:
I am not looking at the camera feeds. I would like to view the camera playback events in landscape mode. Unless I am missing something, I don’t believe your post addresses playback. Again, I may be missing something.
I may not have specifically addressed that previously, but I do view playback (from microSD) in landscape mode routinely for a single camera. During playback, there should be an overlay icon in the upper-right corner of the viewer that you can tap to change the orientation (if it’s not visible, you may need to tap the viewer once to make the overlay controls visible). The appearance of this icon can vary depending on which camera model you’re viewing, because there’s some inconsistency across the UI for various Wyze cameras.
Landscape mode for playback/review on the Monitoring tab has not yet been implemented, as my link to a comment from a Wyze Team member describes.
I hope that clears up some of the confusion!
