Support Intake Forum (using the poll function) 📊
Not perfectly suited to the task but maybe of some utility. :slight_smile:
Nah, prob’ly not.
But still… :thinking:
1   Copy/paste the intake template poll code into the Opening Post or first comment:
[poll type=multiple results=always min=2 max=6 chartType=bar]
* 1 Expertise: Beginner
* 1 Expertise: Intermediate
* 1 Expertise: Advanced
* 2 Platform: Android
* 2 Platform: Apple
* 3 Product: Cam
* 3 Product: Bulb
* 3 Product: Plug
[/poll]
Note
You gotta delete these after pasting the template into a post for the poll code to work.
2   Tick off the pertinent boxes:
3   Close the ‘poll’ (it can be reopened) yielding this:
Here’s the live dummy:
  • 1 Expertise: Beginner
  • 1 Expertise: Intermediate
  • 1 Expertise: Advanced
  • 2 Platform: Android
  • 2 Platform: Apple
  • 3 Product: Cam
  • 3 Product: Bulb
  • 3 Product: Plug
0 voters
It would only be meant to have a single ‘voter’ (the OP) and then be closed, but I’ve left it open for play. This may not work.
Also, mods may not be so interested in having threads littered with these. With the full Wyze stable of products as options they would be… long.
Create a comment here to experiment with this idea (copy/paste template code) or other polling ideas you may be considering.
Seems like @StevenA suggested an intake form recently… :wave:
And this new Wishlist item is about Wyze’s formal support paths (not the user-help-user Forum) but still, some ideas re User Expertise.
The topic has surfaced before: :slight_smile:
Happened to have read about this recently:
Not sure if self-assessment is a good idea. Just saying.
But it is a good idea for people to make it clear beforehand, “I’m not technical”. Support is often in a rock and a hard place because if they say anything “dumbed down” to someone technical, the response can be quite emotional.
Thanks, IL!  interesting.
Howzabout we lean-and-mean it? :wink:
Sidestep the long list of products altogether?
Even if folks mis-self-assess, they’ll be informed that their unpaid helpmates think in these terms? :slight_smile:
The Vent/Problem Solve dual thing - either or both - being primary, imo.
I know you hate Kleenex, but I would like to make a case for when people are venting, they should be directed to an “empathetic” chatbot so they can vent for 10 minutes before a live person takes over. :smirk:
:rofl: Inhumane!
Wow @peepeep. Look at you being all helpful…again. Good on ya! :+1:
The forum has this in a top user who shall remain nameless. :eyes:
Thank you, Slab! I like your phrasing. :wink:
