Sun Match Automations not working (bug?)
I am trying to create automations to toggle sun match under specific situations (sometimes turn it off and turn it on) on various light groups.
However, I am not seeing the setting change (either via the application or the lights themselves changing color) when the automation is triggered.
To verify the behavior, I also created 2 shortcut automations to disable and enable these settings. Running these shortcuts does not trigger a settings change. When I go to the light group’s settings and manually toggle the sun match setting, I am immediately getting the expected change (ie color temperature changing to match time of day when turning sun match on).
