Suggested Improvements for Wyze Scales’ Data Export
Scales & App set to kg however when exporting kg turn into pounds
In Australia we use Kg for measuring weight which works well with these scales, however when we export the results using our email the report shows the weight in Pounds and Kg but all the other readings showing weight are in Pounds.
[Mod Edit]: Title and category modified for better visibility to the Forum community. As the post appears to be similar to discussion in an existing Wishlist > Wishes Granted topic (Wyze Scale Data Export), these edits are intended to create a new and active Wishlist topic for discussing improvements to an existing feature.
Welcome to the Forum, @farside8! :wave:
I agree that measurements in data columns such as “Lean Body Mass”, “Bone Mass”, and “Muscle Mass” should be given in kg. In fact, since the kilogram is truly a unit of mass, it makes even more sense to list these “Mass” measurements in kilograms rather than in pounds.
My main problem at this point with the scale data export (at least what I see for my Wyze Scale S) is that the data is dirty, by which I mean that the data cells in a column like “Weight(lb)” also includes text in addition to the numerical values: A weight of 14.7 pounds (I use Pet Mode frequently) shows as “14.7lb”, so that cell can’t be treated as a number because it’s contaminated with unnecessary text and must first be sanitized. That creates additional work for the user and feels like Wyze is causing a problem that the user has to fix. This shouldn’t be happening.
Other users in the Wishlist > Wishes Granted topic noted above have commented on this same problem:
That’s my primary reason for voting for this topic, because the “Granted” wish is still broken, and I hope that this topic will generate new votes/discussion for Wyze to see so that they can correct this.
Export format form Scale Ultra
The export from the Scale Ultra is “pretty”, but needs a LOT of work to be useful. All fields are text, with the units as a suffix, eg, “167lbs", "57%” .
It would be much more useful to have the fields be numeric, and the column header serve as units.
I agree in the past I have down loaded all my data into Excel, now I find this is not possible using these scales as the data is all in text. Is there a chance the data can be shown numerically?
Export CLEAN csv for scale
Can you clean up your messy data export? Use different columns for date and time or use a conventional formatting option. Remove labels from fields ( like lb from weight). You make it unreasonably difficult to do anything with the exported data without having to clean up your freaking mess first. This is my data, not yours and I, as your customer, deserve better.
[Mod Note]: Your topic was merged to this Wishlist request for consistency in grouping similar requests and for better visibility to Wyze. Please remember to scroll up to the top and click the VOTE button to show your support.
Has Wyze made any progress on fixing this?
Does the exported data still mix numbers and letters in the same cell?
Is there any indication Wyze is going to fix it?
