I am a new Wyze camera user. I am struggling to set up my cameras for consistent operation using rules.
I simply want to have my cameras record, video to the cloud, with notification, when motion is detected.
I created the rules in the attached image. Are they all needed?
I do not want to trigger record or notification based on sound or anything else. However currently the camera is recording 3 times each time. A minute apart. Motion, scene, sound.
Any help as to what I’m doing wrong and or where I can go to find more info about setting these cameras up.
Currently these camera and the associated rules seem very in consistent.
Hi @slotcarguy, welcome to the community!
Rules are not necessary for the basic functions of recording motion events and sending notifications. They allow additional automation of multiple devices like turning on a light when motion is detected, or disabling notifications between certain hours. You can probably disable any camera Rules you have set up for now, then edit or re-enable them later once you have the basics working.
To record events when motion is detected you’ll just need to enable Event Recording:
To make sure you get notifications of those recorded events check your notification settings:
https://support.wyzecam.com/hc/en-us/articles/360030986591-Notifications
Let us know if you’re still having issues. There’s a lot of good info in the Support section.
