Most people are replacing their existing CCTV with Wyze cam. The 12v dc wiring for their old camera still exist and it would be a waste not to take advantage of it.
A kit\ kit to converts 12v to two or four usb, with T-Tap wire crimping would be so useful.
Bought a 12v vehicle USB adapter from $1 tree. Cut the existing female end on the CCTV camera and soldered it to the input of the 12V adapter. I now have 2 outputs per adapter for a $1. Has been working well for me for a LONG time.
Add A Wyze Cam Anywhere You Have A Traditional Security Camera.
I currently Buy an Adapter on Amazon For this…But its a simple 12v to 2 USB power port adapter. Has the same plug as most non POE security cameras. Very Simple. I can put 2 Wyze cams everywhere I have 1 standard security camera currently. Wish to see a Wyze branded adapter!
