Where do the red and white wires from a pump start relay go on the wyze sprinkler controller?
Welcome to the Wyze community @jpe!
The app should show you how to wire the controller during setup. Does it not show this step? I don’t have experience with that type of wiring so unfortunately I can’t answer any further.
They are the C and M tabs, the two white ones on the left. There’s another C tab on the right; those C tabs are the same, since the sprinkler wires also have a common line that needs to go to a C tab.
*Control, Master, is what I think they stand for. Red/M, White/C is how I would set it up first.
