Splicing strip lights & new power source
I just ordered the light strip pro 32ft. Wanted to know if we can cut and splice the light strip to another power source for another outlet?
Cut, yes…splice, not so much. The power supplies are not available for the Wyze strip lights as a separate purchase. Not exactly sure what your needs might be but that’s the info I can share.
I’m trying to use the strips at two different locations in my kitchen and it requires to cut, splice and plug at two different outlets.
As I understand, you need to buy two sets to do what you want. The FAQ mentions this specifically. It seems like you should be able to do it but you can’t get any additional power supplies for them. Wyze also make it clear that they can’t be joined together, only cut.
Got it thanks for you help.
You might want to look at this thread:
