Speaker low sound on Wyze Cam 2
Dear All,
Anyone experience on Wyze Cam 2 with speaker low sound? first setup, I press on Setup but I can not hear anything but when I put my ear close to speaker, I just hear slightly sound about Ready to Connect.
Any solution?
Chynith
I haven’t had that issue. If anything it’s obnoxiously loud in my typically quiet house/neighborhood when I try to set up a new camera :smile:.
You could try doing a factory reset in case it’s a firmware issue, but if that doesn’t help it may be a defective speaker in which case you would need to file a support ticket.
I have the same problem the sound is to low (and bad) to be heard in a 2 way communication.
(I still have to test the range of detection of motion sensor)
