Sourcing … Solar Panel adapter for Battery Cam Pro
Does anyone know of an alternate source for the Battery Cam Pro cable adapter for solar panel charger? Amazon?
With same ends as this Wyze cable adapter female micro usb to usb-c.
Should be able find generic ones on amazon, there are also plug adapters but a cable with the proper ends has less points of failure.
Thanks Dave. I searched on Amazon and did not see the cable. I am trying to find an identical cable to minimize connection points and cost of additional adapters if wrong ends…
It won’t be identical but should be able to find something close. Maybe can find the wyze branded one on ebay or somewhere? But as long as you seal the connection point (which you should do anyway, the little sleeve with theirs isn’t 100% watertight) any cable should be fine.
https://www.amazon.com/s?k=female+micro+usb+to+usb+c&crid=3JUEO1GUHYTPT&sprefix=female+micro+usb+to+usb+c%2Caps%2C777&ref=nb_sb_noss_1
