Sound from keypad
Is there a way to enable sounds for the keypad? I have an external garage that I have a keypad in. Would like to have it beep / sound an alarm when the sensors are tripped as well so that it would scare away anyone that trips a sensor.
To the best of my knowledge, the answer is no. The timer countdown and alarm only come from the hub.
You could put a V3, Pan Cam v2, or Floodlight in the garage and when the sensors are tripped, they engage the Siren on those Cameras. WCOs have a Siren as well, but in my opinion, they are not as loud as the others. Where the floodlight is the loudest.
