I’ve found the IFTT for Wyze MOTION detection but is there one for SOUND?
Yes, but you need to build your own applet. On the My Applets page, click New Applet. Click the blue +THIS link and then search for Wyze. You’ll see the sound trigger applet there. Select it, then follow the reset of the step by step procedure to build the rest of your IFTTT applet.
I’m able to set the Wyze trigger ‘if sound detected’ but then there’s no option to cancel the notification during a certain time frame.
Basically, I want to turn off sound detection during the day.
Yeah, they need to add an Action step Enable/Disable Sound Detection to go along with the one for motion. I don’t know if that’s in the works or not.
