Sorry folks
…the whole Cam Plus Lite thing has become far too confusing and onerous. This was fun when you folks started the company, now it’s just become more of a job for me to figure out what you’re doing. I’m too old to have a another job. I’m out.
Best wishes,
KBS
I don’t know if this will help or hinder, but:
  • Free - Just a snapshot of the event under the Events tab (no cloud clip), plus a link to the full event on your SD card if you have one.
  • Cam Plus Lite (name your price, including free) - a 12-second cloud clip, with person detection. Same link to the event on your SD card if you have one.
  • Cam Plus - adds “as long as motion continues” cloud clips, eliminates the 5-minute cooldown between cloud clips, gives you 2x and 4x event fast-forwarding for cloud clips, provides access to Wyze Web View (in Beta), and adds more identification – packages, pets, vehicles. Same link to the event on your SD card if you have one.
It’s okay really. I’ve just succumb to the “Paradox of Choice.”
Thanks though.
I completely understand. It’s not a huge change but there are little details and also marketing/guilting and it can be too much to wade through. Too bad, though, because “Lite” for free is a good deal.
