Solution: Charging Multiple WYZE Cam Outdoors at once
I found this inexpensive and feature laden 8x port smart USB charging station with LCD, Over Heat and, Over Charging protection.
I have found this to be the best option for charging multiple cameras at the same time in one location.
At least it is for me.
I recommend it. Even though it’s max output for each USB port is 12v-2.4watts. I think it’s close enough and provided overcharg protection
https://www.amazon.com/Multiple-Charger-Desktop-Charging-Station/dp/B075V1HYFS
Let me know what you all think.
I plan to have 12 outdoor cameras running on 3 base stations in the future.
I think this would help me recharge them all when the occasion arises.
Actually each port would be 5V, 7.5W, 1.5A.
I would recommend 2.0A output for faster charging.
This one only has 6 ports but is less money. RavPower is a better known name too.
https://www.amazon.com/gp/aw/d/B00OQ19QYA
I’ll get one and test it out against the one I linked.
Thanks for the suggestion. :hugs:
