Solar panel for V3?
Are there any solar panels that work with the V3 camera ?
There are not any solar panels options that work directly with the Wyze Cam V3. Where the Wyze Cam V3 is not powered by a battery.
There are some community members that have set up DIY battery and solar systems to run V3s, but out of box the device is required to be plugged in using the provided AC adaptor or the (additional cost) outdoor power cable.
Not from Wyze. There may be some 3rd party panels that could do it, but I’d expect them to be beefy and expensive. There are a few of the articles written by members here who have done it themselves if you are interested in the ‘do-it-yourself’ solution. Usually a big panel + battery + regulator.
