Solar Panel and OG Camera
It looks like the OG can be powered by Solar Panel but mine isn’t working…any tips?
Welcome @jjs112264
The Cam OG is not a battery powered camera so the Solar Panel would not provide the continual power needed, especially in the evenings. The Solar Panels are only used with the Wyze Battery Cameras.
Some have tried and use a Battery to power these cameras and then charge the batteries with Solar.
Did you see a reference somewhere which indicated this was possible?
I didn’t see where it was possible, just asking if it was. I’ll buy a battery camera and just use the OF inside. Thanks!!
