Hello is there a drill less way to mount this camera i dont want to drill holes has anyone found a solution
I have a feeling between the weight and the motion of the camera, adhesives or magnets wouldn’t hold it and you risk it falling and getting damaged.
There are some very strong double sided foam tapes out there that you could try. I’d recommend mounting the solar panel separately in that case so each one has its own tape. Do so at your own risk though.
Do you have vinyl siding? If so, there is a solution I use for all my outside mounting that is available from Amazon. I’ll post a link if you have siding or search Amazon for “vinyl siding clips/hooks”. Easily attaches to camera mount and in most cases 1 clip is sufficient or 2 for cam pans and battery cam pros.
