The threaded holes on the bottom (normally for the solar panel) are probably your best bet. You can get thread adapters on amazon to reduce your 1/4" to whatever those are.
Only other idea that comes to mind is to remove the grey mount and epoxy a 1/4" nut (may have to stack a couple) on the back of the cam.
We ended up drilling directly into the metal barn, but broke every screw that came with the camera in the process. Had to switch to steel screws to actually get it mounted.
We should have put it lower, but maybe that’ll be another day, so we can use the full range
Not exactly the easy installation we were hoping for, but it’s up and working!
The solar panel is mounted using a magnetic base, the same setup I used with our older Wyze Battery Cam Pro. That part was thankfully much easier!
I’ve included pictures of both setups in case it helps anyone else trying to figure out how to mount theirs.
Thanks for the suggestion! Unfortunately, glue isn’t a great solution for us here in Arizona. The summer heat is absolutely brutal on adhesives and plastics. We’ve even had the silicone around our existing magnetic mounts deteriorate and disintegrate from the heat.
I do like the idea of screwing magnets directly into the mounting base, though! We just couldn’t find a solution in the amount of time we wanted to put that camera up. He had already been sitting for a few months.
I’m also really disappointed that Wyze changed the mounting screw design on this particular camera. Being able to use magnetic mounts has been an absolute lifesaver around our farm. With all the metal structures, it’s so much easier to mount and reposition cameras without drilling holes into everything.
I really wish Wyze had kept the mounting system compatible with their older cameras. Sometimes the simplest mounting options are the most useful!
