Solar Cam Pan - Better Mounting Bracket
The plastic gray mounting bracket is a little flimsy, not entirely sturdy. I can see if you mount this, and have it in the open, strong winds can take it down. It does lock with its clips, but it also moves slightly when clipped in, plus it is plastic.
Does anyone have a good solution to tighten or maybe there is an aftermarket bracket.
This camera is really good and I am liking it, but don’t what it to be ripped out by winds, then fall on ground.
