How sensitive are the sensors to listen for these alarms? I have them both turned on on the app for this camera and have tested both my smoke and Carbon monoxide detectors. They made the distinct 3 and 4 beep alarms as if there were going off. My camera never gave me the alert. The smoke detector is in the same room as the camera. The Carbon Monoxide detector is up half of a level so I could see that one being too far.
Any suggestions? Otherwise, the cameras are awesome, I keep discovering sweet stuff the camera’s do! I look forward to the update that lets you select zones for the motion detection. How far are you guys away from that happening?
Weird, I will have to try to schedule them. I have the alerts turned on, but I guess not scheduled, I was hoping they would alert me anytime the alarms go off.
How close to the alarms are your cameras placed? One of mine is probably 15 feet max in the same room and it doesn’t send me an alert that the alarm went off. It seems weird you would have to schedule them. Wouldn’t you have to turn the schedule on, then have the option to turn on the alarms? I have mine turned on without messing with the schedule as I want them alerting me all the time.
