On the next build update for the Robot Vacuum, can we make the charger a little smarter?
That would include the following:
- Allowing the charger to be turned on and off from the app similar to a Wyze Plug
- This should allow you to turn off the vacuum from the app as well.
- When the vacuum finishes charging, the charger should go into a low power state (turn off all LEDs) until the vacuum reconnects or needs to be charged more. If the vacuum is at 100% battery, there’s no reason for all the lights to be on.
Thank you!
