To get it to display normally you must load the group in portrait mode, then rotate the device, which can be annoying if your device is in a dock or cradle.
Same on Android, I just meant if you have the phone in landscape as you select the group from the (portrait) home screen. Individual feeds work fine, but groups appear to bounce between portrait & landscape a couple of times then stick in a smaller window view…at least for me.
