Since this morning Oct28 my wyze cameras continue to go offline
I have been using 4 wyze v2 cameras for over a year, they are all well within range of the wifi, also dvr with 8 wired cameras is wired on same router and internet. Since earlier today all wyze cameras started to show go offline and come back on, but even when on i cant really connect except sometimes for few seconds, and now they all show error 90, i tried router reset and such but still same problem. I never had this issue before, i know internet is rock solid and wifi works fine and yet wyze cameras have issue. I believe this is either wyze service cloud issue, or issue with how wyze cameras try to use specific ip on wifi and not let go. I hint at 2nd because had no power last night for 3 hours, but when it came back they were working fine, only later today when problem started… Do wyze v2 cameras fight for same ip after they are added to wifi and if other device takes that lan ip by chance then this can cause wyze camera be stuck in constant on andnoff? Tomorrow i will try to delete all cameras and readd them all onenby one. But this is big pain as i will lose all settings stored like region and event settings… sigh Any ideas?
Error 90, that sounds familiar. Happened to me but on just 1 camera.
Tried everything and nothing worked. Until I re-flashed the firmware. Don’t know why it worked. Maybe a gamma ray reached the earth’s surface and hit the camera …
how do ypu reflash firmware? thanks!
There is also the option of going Beta and then you can presently do it without doing the SD card swap.
Before flashing, try to reboot your WiFi/router
I tried restarting router multiple times, never had this issue before, also wyze app often shows all cams on but then error 48 or 90 and continues to connec, then everyonce in a while connect. This is either wyze side cloud problem, or these cameras really bind to lan ip addresses that somehow jump and conflict with each other if router lost power and came back etc, i will attempt to delete each camera shut off and then readd register one by one again, will report how it goes, again i am not new to them had them active for nearly 2 years but past year been troublefree until power went out sunday, then issues started monday… howver wifi works fine i tested and dvr on same router is accessable remotely just fine as always. only wyze cameras are no longer operating…
